configure cfm segment frame-delay dot1p
configure cfm segment segment_name frame-delay dot1p dot1p_priority
Description
This command configures the class of service for a particular cfm segment. This value is used to fill the dot1p priority bit in the Ethernet header during transmission.
If the optional keyword frame-delay is not specified, the same value of Dot1p will be used for both DMM and LMM. The optional keyword allows configuring different values for DMM and LMM.
Syntax Description
segment_name
An alpha numeric string identifying the segment name.
dot1p_priority
Priority value that is set in the DMM/DMR. The range is 0 to 7.
Default
N/A.
Usage Guidelines
Use this command to configure the class of service for a particular cfm segment.
configure cfm segment frame-delay dot1p 4
This command was first available in ExtremeXOS 12.3.
Platform Availability
